HCHTech
- Pittsburgh, PA - USA
We've got a Dell Latitude 3580, new in 4/17 (so...still under warranty) on the bench for a simple SSD swap and RAM upgrade. It's kicking our butt, so hopefully someone else has been in this corner.
Original configuration was Win10Pro, an i7, 4GB of RAM (Dell, why do you do this?), and a 1TB WD Black hard drive (with 900GB free space).
It would not be impossible to reload, but it would be simpler to clone because of the software load, plus it's a fairly new machine that has always had Win10.
So, like we've done many times before, we backup the data with Fabs, remount the old disk in the machine, run our standard hardware tests (all pass including a gsmartcontrol run on the disk) then use the latest version of the Samsung data migration software to clone the disk to a new Samsung EVO 860 250GB SSD.
The clone completes (maybe takes a little longer than normal, but we didn't time it so that might not be true) without error, we swap in the SSD and get the 'no boot device found' error when we start it up.
Ok, this symptom usually requires some tinkering with the bios SATA settings, so let's take a look:
The SATA section has 2 choices RAID (which is the default setting), AHCI. Secure boot is also enabled, of course since this computer is UEFI.
I also notice that the disk is shown in boot order section of the BIOS, but it does NOT show up in the configuration screen and the drives section. So something isn't right.
We reset the bios to defaults, but that didn't change anything. Still won't boot, SSD is not an available choice when you hit F12 to choose the boot device.
When we re-mounted the old disk, it boots right up, of course. Maybe the original clone got scrambled, so we did a fresh clone. Still won't boot. We notice the BIOS is one version out, so we update the bios, no change in symptoms and it still won't boot.
Ok, let's try a fresh install - it won't boot to our USB installer - hmmm. We remount the old disk and go through the process to switch the bios setting to AHCI. That goes without incident and the machine will now boot to the old disk with the BIOS SATA setting set to AHCI. We re-do the clone and.......it still won't boot from the SSD. Just for fun we disable secureboot, but again, the system doesn't see the SSD. We reset the BIOS to the defaults again, and now it sees our usb installer, so we complete a fresh install without incident, but it STILL won't boot from the SSD.
We mounted the SSD with the unbootable fresh install in one of the bench machines (also UEFI) and it would not boot - but I know the fresh install on the laptop was interrupted at the point of the first reboot, so it didn't technically complete. We did a fresh install with the SSD mounted to the bench machine and it completed 100% and booted right up afterwards. This doesn't make me think there is a problem with the SSD. BTW, once the install booted on the bench machine, remounting the SSD back in the laptop still won't boot. What are we missing?
