[REQUEST] What's the best laptop hinge lubricant?
Appletax
Northern Michigan
I am searching for a dry lubricant that is excellent for lubricating laptop hinges. I have read that dry silicone lubricant is good. One that will not deteriorate plastic. It needs to be truly dry where it doesn't hold onto dirt. I thought the 3-in-1 Oil dry lubricant dropper would be nice, but the comments state it collects dirt. It leaves an oily residue. I like the idea of squeezing out a drop of lube rather than spraying it. I also read that some dry lube sprays are messy. I would like to have good control over where the lube goes.
What do you recommend?
I see that WD-40 makes a quick drying silicone lubricant. I emailed them asking if it would be a good option, but have yet to hear from them. They also make a dry lubricant, which does not specify the chemical used.
I've had fairly good luck with Clenzoil and Lucas CLP - both gun cleaner/lubricate/protect products. The Clenzoil comes in a needle-oiler that is great for tiny area application.
Because these are made for firearms, they are very low in the dust-attraction category and great for lubrication, for obvious reasons. I've also never had a problem with them on plastics, but I am careful to only apply to where it needs to be - assuming that that may be related to being applied to polymer frames.
That looks like a nice possible solution. I wonder if it matters that it's not a dry lube. I suppose if only a small amount is applied that it shouldn't leak out onto the motherboard.
In how I use it, I apply, then wipe all surface oil off. So the only bit that remains is what got "rubbed in" between the compressed washers of the hinge.
Real beeswax furniture spray judiciously applied with a cotton bud on laptop hinges works for me
Which makes perfect sense.
For myself, I don't worry about dust accumulation and will use something like silicone plumbers grease, after a spritz or swab applied bit of silicone lubricant, because it seals that in and lubricates itself. And that's a *thin* surface coat of the grease, not a big blob.
If I can manage to back off the nuts on really insanely stiff hinges, I'll do that, too. I want something stiff enough to hold the screen angle chosen and to stay that way over time. Any stiffer is no help at all, and almost invariably leads to breakage.
