B Trevathan
- Tennessee, USA
Maybe I wasn't clear, I said I WOULDN'T go that high
Raising any voltage may fry your computer, Do this at your own risk
I did NOT say to set your memory voltage to 2.6V from the product information and the links that you provided I read that the Ram you bought uses 2.0V and then I read the spec on your motherboard from the manufacturers website and it says it default is 1.8V and then I downloaded your motherboard manual from that site and READ it and found where to change the voltage
Ram: (x4) Crucial Ballistix Tracer 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory
www.newegg.com/Product/Product.aspx?Item=N82E16820148215&cm_re=Crucial_Ba llistix-_-20-148-215-_-Product
Motherboard: MSI P6N sli (not v2)
From what I read of other people having similar problems they raised the voltage and it solved the problem, I would NOT raise the voltage no higher than what the RAM states it uses.
Try doing this read what I am reading. Read the RAM spec, Read the motherboard manual, Read about similar problems and solutions
