Iconic
- Edmonton, AB
I have a client that I ended up having to do a fresh install of Vista Home Premium on his gaming computer due to a very poor job done by a "pizza tech" that he had out before me. Long story short the guy did not troubleshoot properly and messed up to many key OS files.
So, I went out to the customer and he was ok with having the system wiped and Vista reinstalled. After doing the re-install on site the PC would no longer boot the the HD. HD shows is BIOS, and boot sequence is correct. Drive is IDE so I made sure jumpers are OK and re-seated all connectors. Still during the boot process once it hits the step to boot from HD the system sits there and does nothing.
I brought the machine back to my shop to troubleshoot more and as a first step I replaced the HD with a brand new one and re-installed once again. Install went through OK however on the first boot I got a Blue Screen flash by too fast to read. Unfortunatly F8 in Vista does not give the option to Disable reboot on startup error. I am now getting the BS ever time I boot the system up, and it reboots when attempting Safe Mode as well.
I then put back in the Vista Disk and selected the option to "Repair my PC" to see what it says. And this is what I got:
Startup Repair Cannot repair this computer automatically
Problem Signature:
Problem Event Name: Startup RepairV2
Problem Signature 01: ExternalMedia
Problem Signature 02: 6.0.6000.16386.6.0.6000.16385
Problem Signature 03: 6
Problem Signature 04: 131074
Problem Signature 05: FailureDuringSetup
Problem Signature 06: FailureDuringSetup
Problem Signature 07: 0
Problem Signature 08: 0
Problem Signature 09: unknown
Problem Signature 10: 1168
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Now keep in mind this system only has a keyboard, mouse and monitor plugged into it.
I have ran a Memtest to check that angle along with replacing the Power Supply just as a curiosity test, but issue is still there. I have searched the web and although others out there are reporting the same error line shown in Problem Signature 02, none are showing the same event name or problem signature 04 in combination with problem signature 02.
Does anyone know where I can find something that deciphers this problem signature? or any suggestions on next step would be great.
BTW, the original reason the guy had the "pizza tech" out was that his computer was running slow. No pop-ups or symptoms of virus, but the "pizza tech" did not even attempt a virus check, his first step was a "repair install".
So Symptoms before "Pizza Tech"
*Slow load for general windows use and gaming
Symptoms after "Pizza Tech"
*General windows errors
*Would load webpages but unable to connect to any gaming server like COD
Symptoms after Vista fresh install
*Would not boot to HD
*Will boot to CD/DVD and drive recognized
Symptoms after replacing HD and Vista fresh Install
*Blue screen on regular startup
*Restart on Safe Mode startup
*Error from Repair on Vista Disk
Problem Signature:
Locale ID: 1033
