I've noticed a bit of a slight drop of rates at Nicehash, but that's to be expected. I took my rig down for about 30-45 minutes today to change the PSU, put my new 1000W in, got it back up and running just in time for shop close time, Wednesday I continue building new rack. The new risers I got are working well, can't wait for my final RX 480 to arrive.
If I had the money I would be tempted to buy 4X RX 550 4GB cards, they are on at Amazon for $159 CDN each, by themselves they are not a great card per say, but 4 in a system sharing a system load would break even in a few months. But that is another $700~ish which I just can't do at the moment.
My nylon standoffs arrived from Amazon, at first I though the washers were to thick to go in the aluminium extrusion I have and I was thinning it out with a knife, but then realized it will fit with some finesse. I now have two working risers that are mounted on nylon standoffs to an aluminium base. Nice and sturdy. Once the new frame is ready they will all mount on two aluminium bars which will hold the gpu's, then another bar to hold the lip or edge of the PCI-E I/O bracket since OpenBeam is too wide to fit right under the cards and screw them in, but it has a recessed area that the cards can slide into. It's hard to explain, but hopefully Wednesday I can provide more photos.
I am hoping my new 1000W can handle 2 X RX 480 8GB and 2 X R9 Fury, if not I have one of the cables for linking multiple PSU's together, so I an boost it to 1600W with an extra PSU. If I do that, I will run the HDD from the second PSU to make sure there is some load in case of crash or other issue.
I have lots of older Nvidia cards like a GTX 460 and a 9800GT and 8800GTS etc., most of which Nicehash doesn't support. However, I might put them in one system and see if I can run a miner directly, as if they are running together, it might be worth it.
