I have my small 512 gig SSD NVME and I have a 4 TB regular external just in case.
Word!I never backup onsite - boring sitting there forever. I take the system with me back to workshop and backup from there. using a standard 2.5 external WD 1TB drive with FABS and Macrium.
That eats up time. I have never done this and never has it been an issue. I backup the data 1x and transfer it over to the new computer or new drive (or back to the computer when nuking & paving).I am going to say it again - you need two backups, if something goes wrong you end up with egg on your face when either the data is lost or you have to use customer provided backups if they have them !
Unless you are in an actual data recovery scenario that is overkill. This is a drive used to transfer data to a new machine. Highly unlikely you are going to have your own equipment fail AND not have the original drive.I am going to say it again - you need two backups, if something goes wrong you end up with egg on your face when either the data is lost or you have to use customer provided backups if they have them !
Be sure to check the file system on it. If it is not NTFS, files over 4 gig will not write to it.Here's what I got:
WTF are you talking about? exFAT supports up to files up to 16EB. It's not like a modern drive is going to come formatted as FAT32 nowadays.Be sure to check the file system on it. If it is not NTFS, files over 4 gig will not write to it.
Thank you for the info. Learn something every day.exFAT supports up to files up to 16EB
exFAT (and the other FATs, as well) lacks a journal, and so is vulnerable to corruption when the volume is not properly unmounted or ejected, or during unexpected shutdowns.
exFAT was specifically designed for flash drives due to NTFS's inefficiency on flash memory. It's not meant to hold an OS and I wouldn't recommend it for an external hard drive, but for a flash drive/external SSD it's a nice option.Since I do Windows only and no Apple, I rather have NTFS.
If your goal is maximum speed and you want cross compatibility with Mac OS then stay with exFAT. If you want the data to be a little bit safer, use NTFS. Honestly, just don't pull it out without making sure it's no longer in use and exFAT will be fine. I personally use NTFS with my external hard drives and exFAT for my external SSDs. I also keep a 4TB external hard drive around that's formatted with exFAT so I can transfer large amounts of data from a Mac if necessary. It's rare but sometimes I get in a Mac with 2TB+ of data on it.By default, it's formatted with exFAT. I will be using it to temporarily backup customer data. Data won't be on it for long.
This is how I look at it. If I make one copy and either dies I no longer have a back, just the original. So I'll have to stop what I'm doing to make a backup again.That eats up time. I have never done this and never has it been an issue. I backup the data 1x and transfer it over to the new computer or new drive (or back to the computer when nuking & paving).
I would consider doing it if it were for a business.
