Mike McCall
- Silverton, Oregon
Nevermind. It's portable and therefore doesn't install (insert comment about reading the directions here).
Ok, I get it now. I just purchased Fabs. Oddly, when I first started it I accepted the EULA and it wrote an .ini file to my desktop. If I delete the file it asks again for me to accept the EULA. If I leave it on the desktop it doesn't. I prefer a relatively cleans desktop, so how can I have it write it someplace else?
What?!? This is AWESOME! Now, why didn't I think of that. There are lots of times when making a new profile is the best answer - I am definitely going to give this a try next time.
For someone who's hobby is buying software and then watching it gather dust on the shelf, this program is probably the best money I've ever spent.
Ok, that's impressive.I can relate to that last comment.
The profile in question was in Windows 7 (one admin user). Every time Windows Explorer was launched, it would crash; Documents, Pictures, Computer, any other folders etc.
After removing the antivirus and digging the hell out of the shell extensions in Autoruns and cleaning up as best I could with Tweaking.com's AIO I finally did what I should of done at the start and made a new user. (Had to Run>control userpasswords2 as I couldn't get into control panel)
That user worked fine so I copied everything with FABS from old to new, deleted the old, remade a new one with the same name and copied everything back. Worked great.![]()
FYI, a few versions were released this past week. If you purchased a copy of 5.x or 6.x you should be able to go back to the "store", login, click on the details of your previous order and download from the same link again to get the latest update.
Fab's AutoBackup 6 Pro
Version : 6.1.2.25705
Date : 06/24/2015
Changed/Fixed: Copy errors when restoring "My pictures" and some other folders that were not properly detected.
Version : 6.1.2.25694
Date : 06/22/2015
Added : - Google Earth places (.kml files) are now supported
- Printers listing has been improved : if the printer uses a standrad TCP/IP port, the program says if it is LPR or RAW.
Removed :
Changed/Fixed : - The program's created user accounts did not appear in the welcome screen if they were not local administrators.
- The way to apply the desktop wallpaper has been changed : now, a script is placed in the user's startup folder. This avoids errors when when adding it to the user's registry. The restored or transferred wallpaper may not be visible until the user sing in his account again.
- Configuration ini files can be written with path larger than 255 characters. In fact, the file is first written in the temporary files directory, then moved to its final location).
- The default location to save backup logs has been changed to avoid errors when choosing a drive's root as backup folder. Now, its path looks like "X:\YYYY-MM-DD\Computer_Name\AutoBackup Backup Log - YYYY-MM-DD - HH-MM.htm"
Fabs will restore the files and setup the needed registry keys to recreate the accounts. So sometimes installing outlook after the fact will result in Outlook being properly setup. FABS does not get passwords so you need to use another tool to collect that. But honeslty any tech that wouldn't resetup office for a client deserves to go out of business.How does it handle things that it can't restore? Presumably it just ignores them but I'd like to know for sure.
For instance, when doing a nuke & pave, how much do you reinstall for the customer? I remember someone on here (can't find the post now but it was here, I promise) saying that, for residential work at least, they explain it in builder's terms, ie, we have just refurbished your house (or built you a new one) and now it's up to you to move all your furniture in and to stock your cupboards the way you want them. In other words, we've reinstalled the operating system and all updates etc., now it's up to you to reinstall all your programs, printer drivers etc., etc.
So for example, Fabs backs up, say, the PST file from MS Outlook but, unless you have the customer's copy of Outlook and you install it for them first, Fab's will have nowhere to put that PST file will it, so will Fabs just ignore it?
Sorry for what's probably a silly question but just curious.
But honestly any tech that wouldn't resetup office for a client deserves to go out of business.
^^ agree 100%
If we have to do a N&P, we'll create a list of installed apps and their license keys. Not all programs allow their keys to be retrieved using standard tools, but all the MS Office pgms do. And if any of the programs are email clients (Outlook, WLM, OE, etc), we'll also run Nirsoft's MailPassView to get the email passwords, server names, ports, etc. (As a courtesy, we'll also run Nirsoft's WebBrowserPassView to save their browser passwords and WirelessKeyView to save/restore their wifi network passwords.)
We have the installers for just about every MS Office application, so it's a simple thing to re-install using the client's key. And if an email client is involved, we'll set that up and test it too (Fabs and MailPassView makes it super easy to do this).
We don't re-install everything -- some programs are definitely the customer's responsibility -- but our clients are very appreciative when we go the extra mile. Makes for good referrals!
