sapphirescales
- At My Computer
Just used Fabs version 7.0.4.32756 only to discover that several items were not backed up because they must be manually checked in the program.
My bad that I didn't think to/know that those items should be checked. AFAIK they were checked by default.
Client not happy because data is now gone.
Looks like I need to go back to an even earlier version still or consider not using Fabs altogether.
Too many cooks have spoiled the broth...imo.
Give @fabs a break. It was YOUR responsibility to double check that you got all the data you needed. Autobackup is a tool. When you hit your thumb with the hammer, do you blame the hammer or yourself? Now you DO have a legitimate complaint if the box was checked but the data still wasn't backed up, but that's not what happened. You just ASSUMED that things were a certain way and that everything went well without double checking. That's on you. I use technician software on a daily basis - some of which hasn't been updated in years/decades (and I've been using it for that long too!). I still ALWAYS check and double check that everything is set up correctly before I run it and I also verify that the job was done correctly before I hand the completed project to my client. Software is great, but it's just a tool. A tool is only as good as the carpenter (or in our case, technician) that uses it. A tool is STUPID. It has no brain. YOU are the brain. You can't expect a tool to do your thinking for you.
