Larry Sabo
- Ottawa, Canada
Yes, tried both. Also took ownership of the Windows directory -- no change.Try both the 32 and 64 bit versions.
Thanks for giving it a shot.Yes, tried both. Also took ownership of the Windows directory -- no change.
If this is 2013 or newer, Produkey cannot handle them if I am not mistakenWhat office version are you trying to get? Forgive me if you already mentioned it.
You are correct.If this is 2013 or newer, Produkey cannot handle them if I am not mistaken
Obviously it is.It's Office 2010, according to the client. I noticed that the Installed Programs file was also not generated for reasons I know not. The original Windows installation was broken and could not be repaired or refreshed, so I did a fresh install after backing up the data. I suspect the problems are related.
Thanks for the suggestions, @fabs, but I did try loading from the windows directory of the original drive and got the blank ProduKey window of keys found. Also tried both 32 and 64-bit versions. Regbackup hives have zero length, unfortunately. I considered importing the SOFTWARE hive with regedit to see if the required key is intact or would be found by ProduKey but chickened out when it said it would load them to Computer and delete existing keys.
The client has suggested I discontinue the search; he finds that Ashampoo Office Free is good enough. Many thanks to everyone for the helpful suggestions.
I've been using it since @sapphirescales recommended it and I like it. I wanted to try it with a customer who has constant issues with OpenOffice opening numerous instances of writer or calc that lock up the program but he is reluctant to change. I think his problem is due to system speed (it's slow as snails) but that's another story. I like that Ashampoo Free can be set to save as docx rather than just doc.Has anyone had any experience with Ashampoo Office and Office Free?
OpenOffice.org development is a long way behind LibreOffice, ime – it's a long time since they were equivalent suites.I wanted to try it with a customer who has constant issues with OpenOffice opening numerous instances of writer or calc that lock up the program but he is reluctant to change. I think his problem is due to system speed (it's slow as snails) but that's another story. I like that Ashampoo Free can be set to save as docx rather than just doc.
LibreOffice can be configured to save documents as .doc or .docx by default (similarly for .xls/.xlsx, .ppt/.pptx, etc.).
Just tested now and no problem on my end. Kington USB3 DataTraveler 3 flash DriveAnyone else have a problem with the update when running Fabs Autobackup 7 Pro from a flash drive? It has refused to update on two different systems lately, but updates on my main PC without drama. Sorry, I don't have specs for the systems involved but will pay more attention next time. It used to update from the FD until about a week or so ago.
I had an issue the other day where I couldn't update on someone else's machine, which used to work fine. Something about not being activated, but it worked fine on my main desktop.Anyone else have a problem with the update when running Fabs Autobackup 7 Pro from a flash drive? It has refused to update on two different systems lately, but updates on my main PC without drama. Sorry, I don't have specs for the systems involved but will pay more attention next time. It used to update from the FD until about a week or so ago.
