sapphirescales
- At My Computer
Isn't there a way you could write the functionality into your software itself instead of relying on nirsoft's utilities?
True but I'm assuming @fabs can get his software whitelisted by Microsoft since nirsoft doesn't seem to give a crap whether his tools are detected as malware or not. Unless Defender doesn't take whitelisting into account when a program does something "suspicious."The problem being that it's the functionality, and how it's written, that's what's being flagged.
I already had some contacts with him to just be allowed to distribute his tools with Fab's but that's it.@fabs Isn't there a way you could write the functionality into your software itself instead of relying on nirsoft's utilities? Maybe you could do a collab with him or come to an agreement to integrate his software into yours so you don't have to write it from scratch.
I will not go further as I definitely do not want to integrate such code that WILL be flagged .There's no possible whitelist for that kind of behavior, even if I DO give a ... about my code. Integrating those tools like they are today is clearly the less worst solution.True but I'm assuming @fabs can get his software whitelisted by Microsoft since nirsoft doesn't seem to give a crap whether his tools are detected as malware or not. Unless Defender doesn't take whitelisting into account when a program does something "suspicious."
Well that sucks. You can't get a certificate from Microsoft that would allow your software to do the same things that nirsoft utilities do?There's no possible whitelist for that kind of behavior
I don't think that's even possible. I've never heard about such a "certificate from microsoft" thing.Well that sucks. You can't get a certificate from Microsoft that would allow your software to do the same things that nirsoft utilities do?
To make it work the best, you need to be logged on as the user account that has its folders redirected to OneDrive. It must be administrator and connected to the internet so the files that are only online will be downloaded and copied.@fabs,
What follows is probably "a stupid question" but I know I can get a much faster answer by asking than by digging through documentation.
I have just purchased a new laptop and, as part of the process, have become a subscriber to M365 Family. So, on the new machine, all of the "classic libraries" like Documents, Music, etc., are actually located on OneDrive, not the computer itself. The machine which I will be backing up for restoration on the new machine uses the same Microsoft Account linked Windows user account, but everything is stored on local storage on this source machine.
Will Fabs Autobackup handle this gracefully, without my having to do anything specific, or do I need to take certain precautions/make certain tweaks, when doing the restore?
Thanks again for this tool. It is, truly, *fab*!
This is my process. If the old machine was set to local folders then I have the new machine set to local folders. Once the FABs restore is done then I switch it to the OneDrive folders and let it start syncing to the cloud for backup. It works cleaner this way.Anyway, I recommend that you set back Windows folders to their defaults (locally). That's what I would do if I were in this case (personal preference).
This is my process.
In the OneDrive settings look at the Sync and backup section. The top option on mine is backup important PC folders to OneDrive. There is a button there to Manage Backup. This is where you can choose the desktop, documents & pictures folders. It will redirect the system folders to the onedrive folder and then move all the files there for automatic cloud sync.Anyone care to describe the process, step-by-step, or point to a nice resource for "disconnecting then reconnecting" OneDrive in this way?
The one drive does not instantly upload the files. The new computer has to have the free space for all of the files initially.I got a warning that there was 105GB of data in excess of the capacity that was available on C: (which is true, strictly speaking). I gave Fabs the go-ahead to continue restoring, figuring that during that process OneDrive will end up handling virtually all that data and no issue should occur. That's certainly what I hope happens, anyway.
