So I just started doing a bunch of maintenance that needs done to my vehicles.
My 2010 Jeep Grand Cherokee needs new spark plugs (that I've had sitting on my shelf for over a year now... tisk tisk), new air filter, new PCV valve, front and rear diff service, transfer case service and it needed transmission fluid change but I've "started" that. Dropped the pan, changed filters, and put 4 quarts of new fluid in. I'll have to do the same thing again, since this pan has no drain plug, and right now I only have 50% new fluid mixed with 50% old fluid. Another drop, plus 4 quarts of new will have me at roughly 75% new fluid...
My truck needs new spark plugs (16 of em... ugh 5.7 HEMI lol), needs a diff service on both axles, needs a tranny fluid change and new filters, transfer case, and can't hurt putting an air filter in.
Probably start the truck next. I've been kicking around the idea of buying dorman tranmission pans with drain plugs but I'm a little hesitant. A drain plug would be nice, but I DO NOT want to kill a transmission by running it low on fluid. I'd rather deal with the hassle of trying to drop the pan.
Most of this is pretty easy stuff, mainly because I have access to a lift and don't have to do it from the ground. The spark plugs on the hemi are a PITA. I'm not a small guy, and climbing up on that engine doesn't seem very fun. I've heard pulling the driver wheel and wheel well gives easier access to the rear plugs on the driver side.
My 99 Monte Carlo is leaking coolant, probably needs intake manifold gaskets or the leak is somewhere around the water pump. Need to get that addressed. It also seems to have "power issues"... wondering if the catalytic converter is blocked up.
