AlexCa
Hello everyone, I've just released version 3.0.1.8 of Windows Repair Toolbox. Here’s what has changed:
### Added
- Improved high-DPI support (for instance, the program will no longer look blurry when the DPI is set to 150%, like is common to see on some modern laptops).
- When a new version of Windows Repair Toolbox is available, the program is now able to auto-update while keeping user customizations. It will no longer ask you to go to the website to download the new version.
Thanks to @pctechforhire for insisting on this idea. It got me thinking again about it, and fortunately I ended up finding a way to automate the process in a reliable way.
### Changed
- When setting a startup password for WRT, you will be asked you to enter it twice (in order to prevent typos).
- If you insert the wrong password when entering WRT, the program will no longer close itself (it was annoying having to re-open it).
- Improvements to the "Clear Downloads" function.
- Several other minor improvements.
### Fixed
- If Vipre Rescue was configured to run a full scan (instead of the default quick scan), the "Run Unattended" process would return an error when trying to put together the resulting logs.
As always, if you have suggestions to improve the program, or bugs to report, please let me know.
Thank you!
### Added
Really, you'd essentially be automating the process of what we do when we update it ourselves. It could still be a fresh version.
### Changed
### Fixed
Thank you!
