Hello everyone, I've just released version
3.0.1.7 of Windows Repair Toolbox. Here’s what has changed:
### Added
- The ability to select precisely what tools will downloaded or updated when the "Update All" button is clicked (in the "Settings" tab of WRT). The purpose is to allow the user to download / keep updated only the tools that he wants (thus saving space, bandwidth and time), and, incidentally, to give another way to prevent the AV warnings caused by the Nirsoft tools.
. Screenshot:
### Changed
- In the "Backup & Recovery" section, replaced "DriverBackup" with "CloneApp".
CloneApp is program to backup / restore preferences, settings and other data of supported applications (it supports about 250 different Windows programs).
- If the OS is Windows 10, the information about the specific version will now be more visible (directly in the label, instead of a tooltip).
. Screenshot:
- Removed the message box that would be shown at the startup of the program if for some reason the CPU temperature monitor wasn't available (replaced this with a tooltip). Thanks to the user Omar for the suggestion.
- Improvements to the way the user settings and customizations are stored.
- Updated the 7-Zip components to version 19.00.
- Several other internal updates, changes and improvements.
### Fixed
- If "Windows Repair AIO" was selected to "Run Unattended" (in the "Malware Removal" tab of WRT), one of the repairs performed by it would sometimes trigger a warning message in WRT ("RAM performance monitor will not work"), that needed to be manually closed in order for the process to continue.
. Screenshot:
- The program wasn't deleting the remaining incomplete file in the case of three sequential automated unsuccessful download attempts. This problem would mostly occur with the "MSERT" download, resulting in the error message: "The specified executable is not a valid application for this OS platform."
- If some exception occurred during the deletion of a file in between automated download attempts, the program would not restore several elements of the GUI (progressbar, the labels...).
- If it wasn't extracted and executed at least once, "Firefox Portable" would be downloaded every time the "Update All" button (in the "Settings" tab of WRT) was clicked.
- If it wasn't extracted and executed at least once, "Firefox Portable" would not be deleted by the "Clear Downloads" button (in the "Settings" tab of WRT).
- Several other minor bug fixes.
As always, if you have suggestions to improve the program, or bugs to report, please let me know.
Thank you!
