GTP
- Adelaide, Australia
If you want to get your hands dirty, I'm sure you can find a workaround to get Win 11 installed.Latest report regarding the machine I have that sports an AMD A12-9700P APU: No dice on updating to Win11 v24H2.
I first tried using the Windows 11 Installation Assistant, just so I could say I had, and it pretty much barfs semi-silently and instantly.
I then tried using the v24H2 ISO burned to bootable media by Rufus with all of the things it can neuter (other than Microsoft account, since I'm using one) selected, and that dies early on in the process when the installer throws up a message saying that the processor is not supported.
I knew that the screws would be sequentially tightening and just wondered when it would be beyond worth even experimenting anymore with this. I think I may have reached that point unless the folks at Rufus somehow neuter the check for supported processor, too. Since I wasn't told a new version of Rufus was available, I have to believe the one I'm using is still the latest. It always nags me on startup if a newer version is available.
Make a 23H2 installer with Rufus and try the trick of deleting install .wim in Win 11 23H2 sources folder and replace it with the install.esd from sources folder in Win 11 24H2.
I've done this a few times now while tinkering and it works. I have 24H2 installed on several "testers."
Some of them even receive regular updates like supported hardware PC's.
Prowl around on github. There are a plethora of projects devoted to this very problem.
I found a few that worked a treat, but it's trial and error.
I'm a geek and love "tinkering" so the time I spend is my own - not to mention the satisfaction of beating Microsoft at their game of "We dont want you to do it so na na nana na"
BTW, I'm using Rufus 4.6.2 Beta. Works well.
Post edited to add missing information. Apologies.
