I have just sent the full package to Symantec. They should whitelist it in a few hours
Cool, Thank you.
No problem on my side :Hi @fabs what happened to progressbar when backing up data? Since updating to latest version it is gone.
I like to know how much data is being backed up and what the progress is.
Thanks
low res screens maybe?Hmm.. this is weird. I have tried it on a couple of laptops doing Windows 10 re-installs no dice.
No way. I develop it running W10 and the screen shot I posted is from my development machinePerhaps a Win 10 only issue?
I guess you cannot see the information because of some branding : white text over white background. Can you please post your [branding] section form your autobackup.ini file ?Here we go I did it on another Laptop machine. Actually my wife's Windows 10 laptop clean installed as well. Here is the screen shot, Window was also maximized. Previous versions I had no issues with this.
32-bit applications are limited to 2 GB per process regardless of whatever they're running on 32-bit or 64-bit systems, so these measures aren't going to help it.- Ability to use up to 3GB of RAM on 32bit systems and 4GB on 64 bit systems. This should limit the "out of memory errors" when there is a huge amount of files being copied.
I used this trick : http://stackoverflow.com/questions/2740308/why-2-gb-memory-limit-when-running-in-64-bit-windows. I agree that this is useless for most of 32bit systems because the boot.ini file would not have been changed to handle such memory but 64 bit should be fine because they do not require to set anything else.32-bit applications are limited to 2 GB per process regardless of whatever they're running on 32-bit or 64-bit systems, so these measures aren't going to help it.
If there no local printers installed, the item is disabled. It looks for sub keys into the HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers registry key. In case of a hooked drive, if the system registry hive cannot be loaded, you will get the same result.@fabs Why is the printers list greyed out? I can't get a list of installed printers anymore?
