- Charente, France
Yes it is. This has been introduced with 7.0.3.32618 on May 15th 2018 and is not in 6I don't see such an option with v6 though. Is this new for 7?
I get the computer fully set up and then I restore data.When using Fabs to migrate someone to a new machine, is best to install browsers first then restore data or vice versa?
Yes, it will use Microsoft dpinst tool to scan hardware and install matching drivers, then call pnputil.exe to make windows scan for changes and use new drivers@fabs Will it be able to restore the drivers it backups? Have not had to chance to test.
It does not really matter. In a general manner, I prefer restore first, then install software. This way installers act like if it was an update/reinstallWhen using Fabs to migrate someone to a new machine, is best to install browsers first then restore data or vice versa?
I will give it a test on the next nuke and pave.Yes, it will use Microsoft dpinst tool to scan hardware and install matching drivers, then call pnputil.exe to make windows scan for changes and use new drivers
Thank you for the response. I guess I'll break down and get the new version then...Yes it is. This has been introduced with 7.0.3.32618 on May 15th 2018 and is not in 6
The new version is definitely worth it.Thank you for the response. I guess I'll break down and get the new version then...![]()
First error. There are around 90 of these. I'm assuming I can safely ignore these as they all relate to dropbox.cache. Agreed?
[ERROR] 9/11/2020 9:36:51 AM : Saved file MD5 sum does not match with original file:
[ERROR] "C:\VSS_C_ShadowCopy\Users\Peggy\Desktop\Dropbox\.dropbox.cache\qebcobkqbgpbzfynfuwbof\placeholder.aep" ()
[ERROR] "D:\Customer_data\Peggy Hill\Fabs\2020-09-11\PEGGY-IDEAPAD\Peggy\archive\Desktop\Dropbox\.dropbox.cache\qebcobkqbgpbzfynfuwbof\placeholder.aep" (0F343B0931126A20F133D67C2B018A3B)
Second error: This time dropbox.cache is not involved. Can I / should I ignore this?
[ERROR] 9/11/2020 10:22:43 AM : Saved file MD5 sum does not match with original file:
[ERROR] "C:\VSS_C_ShadowCopy\Users\Peggy\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper" (E64FCBD0D0B45417AF16ACDB34B889CF)
[ERROR] "D:\Customer_data\Peggy Hill\Fabs\2020-09-11\PEGGY-IDEAPAD\Peggy\archive\WallPaper\File\TranscodedWallpaper" (8A806C16FF8B453AE4E148821B607B2C)
Third error: Well, actually a Warning while processing OneDrive files. Again, I"m thinking these can be safely ignored. Agreed?
[WARNING] 9/11/2020 9:26:43 AM : Peggy : This cloud file may be online only and could not be copied "C:\Users\Peggy\OneDrive\Documents\2017-06-05 17.06 New Meeting.g2m"
[WARNING] 9/11/2020 9:26:43 AM : Peggy : Skipping file
Yes, I have forgotten to update user's manual about this. And yes, just leave path blank and logs will be copied to default location, aka where the files are backed up (where there is the backup.conf file).A small low priority program feature request: on the last window before launching the actual data copy (when doing a backup), at the bottom is the option on whether or not to save the log file. And, if you do want to save it, where to put it. Would it be possible to add a check box to specify that the log file goes to the same directory where the backed-up files go? I realize it's not that much effort to navigate the dialog box to get to where you want it, but for some reason this bothers me.
Or, if you leave the destination blank, it will go where the backed up fies go.
P.S. this function does not seem to be documented in the User's Manual
Thanks for listening.
Harry Z
Yes, that's a cache file that possibly changed a bit while copying as backed up file is from a VSS snapshot. This also happens while backing up Firefox profile while it's open but copied file is in a good shape. Anyway, that ".dropbox.cache" folder should be excluded anyway. I put that in To Do list so this will not happen again.
This time, copied file has no reason to be different from original one. Is source or tharger file system corrupted ? No other idea so far. At least, it's just wallpaper. Just check content between
"C:\Users\Peggy\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper" and "D:\Customer_data\Peggy Hill\Fabs\2020-09-11\PEGGY-IDEAPAD\Peggy\archive\WallPaper\File\TranscodedWallpaper" and see if saved wallpaper opens fine and is the same as the one in source if that matters.
Yes, this one can be safely ignored. There's no file corruption or copy error here. It just means that source file is not really on source drive but in the cloud. That "C:\Users\Peggy\OneDrive\Documents\2017-06-05 17.06 New Meeting.g2m" file is in fact some kind of shortcut to the file in the cloud, so, it is normal that Fab's could not get it.
In a general manner, it does not change my answer. The explanation must be different then. The fact you were running PE makes it strange that files were copied from a VSS snapshot while this feature is designed to be totally disabled as it's useless. VSS point should never have been created. Which PE were you using ?Mahalo for the response. I forgot to mention that these errors occurred when backing up data from a machine booted from a PE disk so nothing should be changing during the Fabs run. Does that make any difference in your answer?
Thanks. Now I need to figure out a more reliable way to detect PE every time to disable that vss feature which is useless in this caseGandalf’s Windows 10 PE x64 Redstone5 build77763 version 09-01-2019
It's mentioned in this thread:there is a @Recovered directory. This is not in the source hard drive, so where did this come from? (I did check the User Manual)
