- Charente, France
Yeah, William profile seems to be corrupted for while. For some reason, Windows could not use C:\Users\William profile to store his files. When this happens, it often creates another profile with user name in it, a dot and domain name as suffix. In this case, then PC is not in a domain but in a workgroup called "workgroup". This is why Windows created "C:\Users\William.workgroup" and has stored user data here. First profile can be safely ignored as it's just garbage. When users logs in as William, his profile is William.workgroup.New couple of questions / issues. I'm working on a Win 8.1 machine that is several kinds of messed up with the user profile stuff. A little background before getting into the Fab's specific stuff.
There are two userids:
- William
- William.workgroup
William seems to be corrupted in some way. If I go to C\Users\William instead of seeing the usual several folders, there is only AppData and My Documents folders. My Documents contains just 1 folder and a couple of documents. AppData only has a Local directory, and underneath that is just a Microsoft directory with a few more levels under it. Very strange. (Yes, I have turned on viewing hidden and system files). William is the user name used to logon to Windows.
William.worgroup has the expected plethora of folders and files at C:\Users\William.workgroup. Lots of documents under My Documents. There is no option to logon using William.Workgroup
When I run a backup in Fab's I get a message about some sort of registry error for William and literally nothing is copied for William
William.workgroup has lots of data copied, but in the backup under William.workgroup | archive | Documents, there is a @Recovered directory. This is not in the source hard drive, so where did this come from? (I did check the User Manual)
My goal here is to delete both William and William.workgroup and create a new user with the combined data from both userids.
Mahalo,
Harry Z
The other question is well answered by @fincoder
