Fab's AutoBackup 7 Pro - a must have tool for techs
Regarding the installed software & printers reports, why are they sometimes saved in a folder on the desktop? Other times they're saved on the desktop directly? It might depend on whether it's a transfer or restore, but I can't think why except maybe a bug.
Obviously not a serious issue, but it just seems unnecessary to open a folder to get to a single file. The report files should be either placed on the desktop itself, or all placed into a single folder for grouping purposes. Not an individual folder for each file.
Making such lists is not Fab's main purpose. There isn't such an "export" list feature as they are part of a backup/restore or transfer process. However, it's possible to put them in a specific folder but only while transferring or restoring data. For that, edit autobackup.ini file and add ReportsStorage=Z:\Folder_where_to_store_reports value under [CONFIG] section. This way, resorts and exports (nirsoft exports too) will be stored here.
Ah np my bad I think, as ran the backup with HDD connected into Caddy sorry. No warning regarding Hives - is there something I can do in future?
All cool thanks :)
Thanks for that. New test done in similar conditions (mounted VHD) and software list was exported correctly. So far, I can't see any program bug. Are you sure the box was ticked ?
My main question was about why sometimes the 'installed software list' (and other reports etc) are sometimes stored in a folder of the same name, just to hold a single file, but other times just the file itself is placed on the desktop. It might be transfer & restore that behave differently in this regard, but why? I'm just suggesting that the unhelpful subfolder created isn't necessary, and obviously isn't because some operations don't create it.
I assume the ReportsStorage setting just replaces Desktop as the location, but there would still be individual subfolders created with a single file in it.
Every time a report ends up in it's own subfolder on the Desktop, I have to drag it out to the desktop. Because I often open these files more than once, and often leave them on the desktop for the customer.
Just a minor annoyance, something for you to look at later if you want. No need to interrupt other more important work!
Right, transfer mode do not create such folders. There's a simple reason : sometimes, people use Fab's to make backups from the same system regularly in non dated folder names, there can be lots of versions of those lists. Imagine, you use Fab's to backup a system every day and you decide to get installed software list back while restoring. If they're not stored in such a folder, imagine how charged the desktop will be. At least in a sub folder like that, desktop stays as clean as possible. That's the only but understandable reason.
That's right, I may try to do something about that. Like if this variable exists, then it should not create sub folders.
OK, fair enough. I didn't think of repeated backups, makes sense now.
I only mentioned it because I thought it was an oversight or bug. Now I know it's by design, no need to change anything. It's only a couple of extra clicks for each report after a restore, I can easily live with it.
Thanks for your reply.
You're welcome :)
Is there a "take home" version of Fabs?
A customer has a laptop that died. I'm copying everything from it's hard drive to a new external USB drive for him. He won't be using it right away. I'm thinking I'd like to say "run this when you get it connected down the road and it will restore everything to your new computer for you".
I don't think he'd be wanting to pay for it. And I don't really want to devalue what I (we) bring to the table. But, sill curious if there's a portable free version this guy could use. @fabs your support here is great, but don't run off and write one just yet. :D. This may never come up again.
So just download this for him and he could restore all 63GB of data to his new computer using the trial version of Autobackup 7 Pro?
Yes sir. Trial version has limits in backup and transfer mode but not restore.
You could also provide it to him and brand it a little bit.
Edit : I've looked at my code and there are some glitches in this configuration with some items not working as expected. I'm fixing them. This will require an update.
If you need it fast, I'll send a link in a private message so I won't have to hurry with an official update ;)
And yet, you are. I give people the files and tell them that I can properly restore them. Why are giving away the secret sauce?
Not just the secret sauce, the keys to a heavy piece of machinery that they have no training or experience in. I mean, Fabs is easy to use... For a tech.
On that note, I know another one of my tools not only has the password option to protect the licence, but also a manual licence expiration control for the licence holder. I don't even know what app it was (MAYBE Fabs? I've never looked) and I wondered about the use case. Now I know ;)
Fab's has a password option for the techs who leave it on end users machines. If a password is set, license information is encrypted in autobackup.ini file and in the registry. This prevents end users from running the tool.
Because it's a commercially available piece of software and it's our duty to serve our clients best? Sometimes that means giving them a quick piece of advice to allow them to DIY successfully.
And doing just that gets you good will and incredible word of mouth advertising on more than one occasion. Worth its weight in gold.
