- Charente, France
I guess he has digital password so he can unlock it and copy dataSo what happens when bitlocker is turned on?
So does that have to be done from a system with bitlocker (TPM) capable or enabled? Can an old (say gen 4) system do that?I guess he has digital password so he can unlock it and copy data
I had that today when trying to copy Edge files with FABs. Couldn't copy any of them. I had to manually kill the backup.If there are lots of copy failures within a set of files,
I think that windows can unlock bitlocker drives on any system as soon as bitlocker digital password is provided.So does that have to be done from a system with bitlocker (TPM) capable or enabled? Can an old (say gen 4) system do that?
He had this while running a portable win10 install on a USB SSD, so errors came from (I guess) lack of permissions on source driveWhat version of Fabs and were you on a live install. My older version had no errors.
Since Chromium-based browser data is encrypted?He had this while running a portable win10 install on a USB SSD, so errors came from (I guess) lack of permissions on source drive
I don't know. I think about NTFS permissions, not encryptionSince Chromium-based browser data is encrypted?
That would be GREAT!Another possibility that could save some time : I could also do something like passing "C:\Users\CrazyDude\Documents" AND "C:\Users\CrazyDude\Documents\Taxes\2021" BUT I would use an option that will not look inside sub folders.
Actually I just did another transfer today. About 500GB worth of data. I got a bunch of errors. I did this one in the native running operating system because I figured I might have better luck that way.He had this while running a portable win10 install on a USB SSD, so errors came from (I guess) lack of permissions on source drive
It doesn't matter what the computer is in for. I decrypt the drive and convert it to a local account. If I'm doing a nuke n' pave, I decrypt the drive before extracting it and using Fabs. Then I install a fresh copy of Windows with a local account and transfer their files over again using Fabs.So what happens when bitlocker is turned on?
My main office machine is a 4th gen i7 and I decrypt drives with that machine all the time.So does that have to be done from a system with bitlocker (TPM) capable or enabled? Can an old (say gen 4) system do that?
I do it this way sometimes too but it doesn't seem to make a difference. There are always errors. Usually only a few dozen on small transfers, but I've yet to have one completely successful transfer without errors.we run it from a Windows bench machine which has the customer's drive in a hot-swap bay.
I've never tried running Fabs as administrator before.
Yeah, it's definitely not a permissions issue. When it backs up 733/748 files under the Documents directory, it definitely has permission to read content in the Documents directory.Can't blame the application when it has to skip items for which it has no permissions.
I would be so sure about that. What about a sub folder with special permissions on it ? The fix might be just some kind of permission check and adjustment when it hits a sub folder.Yeah, it's definitely not a permissions issue. When it backs up 733/748 files under the Documents directory, it definitely has permission to read content in the Documents directory.
Fab's AutoBackup Pro prompts for admin rights at startup so it always runs as administratorCan't blame the application when it has to skip items for which it has no permissions.
Fab's AutoBackup Pro prompts for admin rights at startup so it always runs as administrator![]()
Sure. I'd be happy to see if it's a permissions issue, but I highly doubt it. On my main bench system I've turned the permissions BS off on an account-wide level so my user account completely ignores permissions. I haven't done this on my portable version of Windows 10. When I run Unstoppable Copier I don't run it any differently than I do Fabs and it has no problems at all whatsoever accessing any file.would you mind testing some development versions
I've sent a link for a test version in a private message.Sure. I'd be happy to see if it's a permissions issue, but I highly doubt it. On my main bench system I've turned the permissions BS off on an account-wide level so my user account completely ignores permissions. I haven't done this on my portable version of Windows 10. When I run Unstoppable Copier I don't run it any differently than I do Fabs and it has no problems at all whatsoever accessing any file.
Okay I'll get back to you. I'm going to re-run a backup I recently did that had a lot of failed files. There's about 500GB worth of data in this backup though so it will probably take a long time to finish. I figured this would be a good test since I've already backed this system up before. Unfortunately I don't have the original log file but I'll pass on the new log file to you once I make sure there's no personally identifiable information in it (unless of course there are no failed files this time, in which case I'll be very happy).Let me know if that addresses the problem.
