Hi all ,
I've just released the version 1.0.0.5 BETA of Windows Repair Toolbox. The most noticeable thing about this release is that the baseline of tools that compose the toolbox has changed quite a bit, in order to make it as useful as possible for everyday use and to cover most needs (while trying to avoid bloat).
Here's a print:
And here's the full change log:
Fixed: Windows Repair Toolbox will fail to run if Windows have the Performance Counters corrupted (Form4 error).
Improved: the tooltips will now remain visible for more time.
Improved: some internal improvements in order to increase the robustness of the tool.
Improved: the baseline of tools that are part of Windows Repair Toolbox. Several tools were added and others replaced, in order to make WRT as useful as possible for everyday use and to cover most needs (while trying to avoid bloat).
Some notes about some of the new tools:
. In the first tab (“Tools”), there’s now a group box called “Hardware” that only includes hardware diagnostics and troubleshooting tools.
. Under “Backup&Recovery”, if you click the “TD&PR” button (Test Disk and Photo Recovery), a new message box will open and ask if you want to run TestDisk or PhotoRec.
. Under “Useful Tools”, if you click the “Nirsoft.PWD” button (Nirsoft Password Recovery Tools), a new message box will open giving you the choice to browse all tools, or to immediately run one of those most commonly used: WirelessKeyView, BrowserPassView or MailPassView.
. Under “Useful Tools”, if you click the “Nirsoft.SYS” button (Nirsoft System Tools), a new message box will open giving you the choice to browse all tools, or to immediately run one of those most commonly used: BlueScreenView, WinCrashReport or ProduKey.
. Under “Repairs”, the “FixWin” button will download FixWin 1.2 (for Windows Vista and 7) or FixWin 2 (for Windows 8 and 8.1), accordingly to the Windows version where Windows Repair Toolbox is running.
. Under “Repairs”, both “Zoek” and “Farbar Recovery Scan Tool” will allow you to choose the location where you want to save and run the tools from.
. In the second tab (“Malware Removal”), under “Optimize”, the “Disk Defrag” button will now download and run Auslogics Disk Defrag portable.
Some other minor improvements and fixes.
As always, all feedback, bug reports and suggestions are much welcome!
