I have always got an installed list wth Fab's
Since software is installed on a machine level, it makes sense to have it there. What a mess it would be having to dig in every user backup to find itI keep forgetting it's in the "Public" archive and not the user's archive that I'm restoring.
That feature would be nice, and it would be relatively easy to do by using ninite.com for the download links. Maybe Fabs would need permission from the Ninite developer though, which would probably rule this option out.Instead of just giving a list of installed software it would be great if Fabs actually prompted you to install the software that was in that list by providing live download links that could be simply clicked to install them.
Why would you need to copy the profile over again? It seems to always work by installing the app after the profile data is restored.Too many times I've run the backup then realised that Garmin, Chrome or Skype etc was missing then have to install them and run the restore again to copy over the profile etc.
Previously I've asked about the possibility of logging the default browser from a source system. Would the trick you mention help with this potential feature?- The default browser detection method has been improved (thanks to Alex from Malwarebytes for the trick). Now the various pages and html logs open in the right browser.
Fabrice would have to chime in on the implementation side of this in Fabs Autobackup, but it should be possible from a purely technical perspective. You can actually identify the default web browser of a user on an offline or online Windows OS if you know how it works. The pieces to the puzzle are all stored in the user's registry hive and SOFTWARE registry hive.Previously I've asked about the possibility of logging the default browser from a source system. Would the trick you mention help with this potential feature?
Setting the default browser is important on Windows 10 systems, because most people don't use Edge and third party browsers can't make themselves the default. When restoring a customer's system it's difficult to figure out which browser they prefer to use, most have a third party browser installed but they might not be using it. It would be great if the default browser was mentioned in the Installed Software List report.
Very true, but lets not forget, in order for that to actually work, you would have to have the browser installed prior to restoring from backup. Although its a moot point if the default is Edge. If that is the case, simply install Chrome and make it the default.Fabrice would have to chime in on the implementation side of this in Fabs Autobackup, but it should be possible from a purely technical perspective. You can actually identify the default web browser of a user on an offline or online Windows OS if you know how it works. The pieces to the puzzle are all stored in the user's registry hive and SOFTWARE registry hive.
No, not to simply log the name of the default browser in the Installed Software List which is what I was suggesting.in order for that to actually work, you would have to have the browser installed prior to restoring from backup
This!third party browsers can't make themselves the default.
This!
Never wondered why they can do that in Win 7 and not in 10?
I suspect there are some kind of builtin protection in 1 that prevents the default browser to be set programmatically or third party browsers would still be able to do that.
Finding out which browser is default is not an issue anymore. Setting it is! This can only be done using the dedicated Windows settings window on 10. No program can do that or you can be sure that third party web browsers would do it like they did before Windows 10!This will tell you the default browser.RGSA (Rocket Grannie Security Analysis)
If Fab can figure which scipt does this at lease you know which browser was set as default.
Yes Win10 blocks that now. I'm guessing it probably also blocks the default email application and who knows what else.Finding out which browser is default is not an issue anymore. Setting it is! This can only be done using the dedicated Windows settings window on 10. No program can do that or you can be sure that third party web browsers would do it like they did before Windows 10!
PDF reader as wellYes Win10 blocks that now. I'm guessing it probably also blocks the default email application and who knows what else.
Which is why I'm suggesting that the default browser is logged in the Installed Software List report. Then the tech can manually set the default after installing the browser.Finding out which browser is default is not an issue anymore. Setting it is!
LMFAOSo you'll want to implement some sort of AI that can emulate everything the user would need to do to change the default browser despite anything that Microsoft might do to block it, then? A nice little project for your free time.
We'll expect the new version by Monday.
I would like to know the default so that I can set the computer as close as it was when it came in.Which is why I'm suggesting that the default browser is logged in the Installed Software List report. Then the tech can manually set the default after installing the browser.
