GTP
- Adelaide, Australia
FWIW it is working fine for me.
@AlexCa ok, strange thing. Versions correct. I decided just to have a look in WRT's folder and PatchMyPC (updated) is there. However, trying to download it, it just hangs in the app. Nevertheless, it does download to the correct folder. Weird
It works perfectly
@cyde_ePhex
I imagine that if you now open WRT and click the PatchMyPC button it will ask you if you want to download a new copy.
If you press "No", it will run PatchMyPC.
If you press "Yes", it will try to download it a few times, until it gives you the error "Several attempts to download this file have failed."
Is this what is happening?
This is exactly what is happening. Also just checked with SDI Origin. Same thing, except SDI is not in the downloads folder
Just for giggles I thought I would time how long it took me to update to the latest version.- Replaced "Treesize" with "WizTree", after reading about people using it in the Software you keep on a USB thread. It's indeed a faster solution.
Hey @AlexCa I'm trying to download and run Macrorit from the GUI of WRT, but after it downloads I get a very brief flash of the program trying to open then an error:
Not being stopped by my AV (Emsisoft) because direct download from the Macrorit website (portable version) works perfectly.
@AlexCa
Are you aware of the Reset Windows Update Agent?
You might include some features into WRT...
I just put this .cmd file in my "Custom Tools" section. Just double click to run.Hey @TechPJC , thank you for the tip, I'll give it a look![]()
