AlexCa
Hey guys, I've released version 2.0.0.3. This version contains improvements to the "AVLeftovers" functionality that I've added in the last version:
- Made several changes in order to improve detections and reduce false positives.
- Removed detections regarding some older discontinued AV's, and added several other detections (so there's no longer a total correspondence with the "AV Uninstall Tools Pack").
- Increased the size of the form so that it's easier to look at the paths when the nodes are expanded.
While this functionality is not perfect - false positives can occur and it will not tell us the exact version of the AV detected - , I think that it will make the task much easier. Admittedly it relies in part in the knowledge and the experience of the user to cover the two weak-spots mentioned above. If you guys feel like, give it a go and tell me what you think. The tool doesn't change or remove anything (and neither is it supposed to do so), but it only reports (if you right-click a node you'll only have the options to copy the path or to open it - in order to allow to examine the contents).
Thank you.
Thank you.
