AlexCa
@Barcelona
Hey Greg, are you still getting the same error? The download seems to be working fine here. However for some reason that download sometimes gives an error. Usually it's temporary. I'll probably be changing the download link to MajorGeeks.
Anyway, you should at least, go to the "Settings" tab and click "Clear Downloads" and then click "Update All" (to re-download everything once again). When asked if you also want to delete the downloaded custom tools, you can answer "No". This is to make sure that that everything works as intended regarding the management of downloads. The changes made to this version will surely cause troubles if the "Downloads" folder of older versions is kept.
@MDD1963
That's because Smartmontools, that I'm using to get those attributes, still have limited support when it comes to NVMe drives. It can't retrieve information about that drive. Just to make sure, try to run GSmartControl. It should give you "Unknown model".
@MDD1963
