sapphirescales
- At My Computer
Every copied file is compared to its source (date and size). If there is a difference or a copy failure, a warning or error entry (depending on the case) is added to the log. It just does not show every file OK on the log (except in debug mode) to limit memory usage.
I am not sure on how I can handle damaged files. That's a tricky thing
Who wants to look at log files? Unstoppable Copier shows the number of successful transfers, failed transfers, errors, etc. at the bottom of the transfer window. It also slows each file as it's copied in a table format, allowing you to sort the file list after the transfer is complete so you can see what files failed to transfer, sort by name/size/whatever, etc.
Unstoppable Copier is a free program, and the guy that wrote it is a great dude. You should get in contact with him. Maybe partner with him. His copy engine is second to none. You can even choose whether you want to choose "fastest backup" or "best backup," the latter of which tries to copy damaged files over and over again and hammers away at it until you get as much of the file as possible.
But honestly, damaged files would be great but what's more important is that you can see how things are transferring as it happens. A live log at the bottom of the transfer window is an EXCELLENT idea, and not something many programs implement. You can still write a log file if you want, but I don't want to have to look at log files all the time. If it says that it copied all but a couple of files, I'm probably OK.
Unstoppable Copier hasn't been updated in many, many years. He might be willing to give you the source code to it. It never hurts to ask.
