Fab's AutoBackup 7 Pro - a must have tool for techs
Hello,
Fab's AutoBackup 7 Pro and Fab's AutoBackup 7 Home & Office 7.12.1.5971 have just been released.
Here is the change log for both versions:
Fixed:
- If user profile path changed between backup and restore (because of a different user name for example), paths for Microsoft Office recently opened files list were not changed to match new user profile path.
- The program could crash when trying to expand the "recent" folder (like C:\Users\User_Name\Recent) from the additional folders explorer tree. Since this item can lead to very unstable behavior, this folder des not even appear in it now.
- The program could hang while running Nirsoft tools. Now, if it calls a Nirsoft program and it runs more than 20 seconds, it will be terminated and the program will process the next item instead of being stuck.
Grab it from your orders history's details on the shop's website at https://archive.fpnet.fr/account.php (ordered before May 1st 2022) or https://store.fpnet.fr/en/order-history for newer orders. You can also use the bundled updater tool (click the "Download Fab's AutoBackup 7.X" link within the program and get the updated files).
FYI, When I tried to update, I got this. Went ahead and downloaded a new copy manually.
Humm, if you could download, it means that you have a valid license, otherwise, you would not be able to get it from website.
I guess you renewed your license but not changed the information within the software.
For this, use the key shaped icon on the main window and select "update license information". Then, provide your current license information and click OK. That should be fine next time.
If I'm wrong, then please send me your current license information using private messaging and I'll check that.
Over the years of reading about Fabs AutoBackup I've thought, "That's a great tool, but it's not something I often have the need for given what I typically do." While that remains the case, overall, I have a new client where I will be acquiring 4 new machines and where I would love to have the ability to just transfer, wholesale, all of the user data and settings from each to its replacement. I believe there are only single user logins on each of these machines, which I have to verify, so multi-profile capability is not likely needed.
I've taken a look at the Fabs AutoBackup webpages and, in this situation, I believe that Fabs AutoBackup Home & Office would suit my purposes, but it's not clear to me whether it is licensed for any commercial use or not. If not, then I would have to purchase Pro. I don't want to violate license terms, so I thought I'd ask here, since the developer is a regular and there are many regulars here who already use Fabs AutoBackup and have for years.
I totally agree with @nlinecomputers. Yes, Home & Office version can do the job but it is less handy for that as it's not portable and has to be installed on each machine. Pro is portable and can be used on as much computers as you want.
Just the "Pro is a portable program" factor is enough for me in this case.
Since most of the work I do is for residential clients who have (generally) minimal data as far as storage locations go, and most these days are using browser sync features for their settings, it's generally easy enough to set up someone on new hardware by hand.
That will not be the case for this new client, so I'm following my own advice of finding the correct tool for the task, and Fabs appears to be it. I've already downloaded the trial version to play with so I have some familiarity before snagging the real version for use in the field.
You won't be sorry! This tool has saved me so much time over the years it's not even funny! Not only do you grab the actual data but the program acts like a real-time checklist so that you don't forget important things like wi-fi passwords and software keys.
And because one of the machines is used almost exclusively for QB, and the experience I've had with QB still gives me the chills, anything that automates the transfer of everything *but* the program itself from old machine to new is critical. Worth it to me just for that alone (but there is more, and I agree it's all of worth).
I've purchased Fabs AutoBackup Pro, and have activated the trial version I downloaded with the order reference number and email address used without a hitch.
Since this is a portable program, I am presuming that if I copy the activated copy on my computer's main drive to any other media, that the activation comes right along with the copy. Is this presumption correct, or will I need to keep a small text file with the order reference number with me to reactivate it when using it on other machines in the field?
(@fabs in particular, but anyone who knows feel free to answer)
Just keep the program's folder and its content and you'll be fine
The reason for that is FABS as needed will download supporting programs to do certain functions like getting WiFi passwords. It needs to download utilities from NirSoft to do that. FABS is in many ways a front end for other free utilities.
OK, now the second "beginner's question." Were I dealing with two fully intact computers where I was trying to move content from one to the other the way I'd think I'd do it is backup on the source machine then restore on the target one. But my first case is going to be dealing with the AIO I posted pictures of, that's dead as a doornail, and where I'm going to have to extract the system drive from it to do anything. So, in that scenario, it seems to me that connecting it as an external drive on the target machine, then using the Transfer function would be the way to go. Am I missing something?
@nlinecomputers and @fabs: I have kept the entire folder, which started out life as the trial version, intact. I activated the program there and then moved it (on my source machine off of the root of C: to elsewhere) then proceeded to copy that folder lock, stock, and barrel to two different USB thumb drives. If I'm reading what you're saying correctly, it's possible that over time Fabs may fetch the various NirSoft or other utilities on an "as needed" basis and, if that occurs, I should really then copy the "updated" folder back to wherever else I might be carrying or storing it. Would that be correct?
The transfer feature is designed for that purpose so yes, you're right.
About the nursing utilities, they're part of the bundle now so there's no problem with that. Just stick with the activated copy
