GTP
- Adelaide, Australia
So we all hear it, right? Lol
Sorry to "nitpick" but just a small thing. I noticed you spelled "below" incorrectly and also on your website as well.![]()
sounds like xml config missingHey Alex, just downloaded the latest "Portable" version and unzipped it to an empty folder.
When running the exe I get "Root Element Missing" about 4 times before the program starts. I removed the folder completely and redownloaded it but same result.
Tried again, same again!
Download to a different computer, same message.
WRT opens and seems to work fine though?
i tried it just now and it was fine. the config is there and no errors during startup. do you see the "Windows_Repair_Toolbox.exe.config" file there?Hey Alex, just downloaded the latest "Portable" version and unzipped it to an empty folder.
Yep, It is there. I copied the file from another location (previous version folder) to the new version folder and it works without issues.i tried it just now and it was fine. the config is there and no errors during startup. do you see the "Windows_Repair_Toolbox.exe.config" file there?
Check Updates works fine. Everything else works perfectly.Hi Barcelona, do you receive the same error if you go to "Settings" and click the "Check Updates" button?
Are the downloads working? Thank you.
I just get that message whenever I start the program.
On the settings for unattended, we should be able to turn off Defrag as SSDs are not supposed to be defraged, and also, since Windows 8, HDDs don't need TO BE defragmented either.
Also, get an error when downloading Microsoft under Security as saying Several attempts have failed.
Oh oh... this keeps happening...
Well, this is what I get under Malware Removal > Microsoft
The odd thing is, once you click Microsoft, it highlights Vipre Rescue.
@AlexCa would it make sense to do the chkdsk on %SystemDrive% instead?
